Congratulations Rawley! I think I know exactly how you feel!
As others have hinted you could have a failing IMS bearing leaking the oil. You should at a minimum remove the oil filter & inspect it for metal. You need a 74mm oil filter wrench & about a half quart of oil to replace what drains out.
