Can't clear abs code
After battery died and was slowly recharged (2 amp), the abs failure light and brake fluid level lights are on. The obc flashes abs failure and brake distribution failure. Speed sensors seem ok when checked with ohm meter. Durametric apparently can not reset these codes. Brakes seem to work fine but no abs. Fluid level is not low inspite of indicator light. Disconnecting battery also did not clear codes. Durametric does show 4276 low voltage to abs valve which clears but comes back. Any ideas about how to clear these codes. I thought this was something Durametric could do. (Sorry to post here meant to start new thread. )
