Originally Posted by opus69
You might want to pull the motor out and directly apply a 12V source to rule out the motor. I would then check the e brake switch next as it has to be engaged and working to have power to the motor.
I've been thinking of that but Im afraide im might brake it. And im not sure how its working i think is turning the pools depending of with direction up/down it should go.
the e brake switch wich one is that?
