Old 07-30-2013, 01:55 PM   #23
aclark133
aclark133's Avatar
Originally Posted by stephen wilson View Post
Sorry Ekam, but that's not true. If the Net offset is the same, your wheel bearings don't know if you have a spacer or not (assuming they are quality, and hubcentric). A 45mm offset wheel is effectively the same as a 35mm+10mm spacer. Anything that still fits in the stock wheelwells will NOT be enough to affect the wheel bearings.
This isn't true either. A 35mm offset with a 10mm spacer equals 25mm offset
aclark133 is offline   Reply With Quote
