Old 07-30-2013, 11:49 AM   #1
tranceatlantic
I swapped out these LEDs this weekend and everything went well. The latest LEDs posted by particlewave are actually the same size as the old ones which makes life a bit easier. I am by no means an expert at soldering but I didn't find it too hard. Each LED on the board is oriented in the same way (they have a cut-out on one corner) so you can replace one and then test it before you change all of them. Getting them to stay in place while you solder them on is the hardest part. I used a small screwdriver with petroleum jelly on the tip.
tranceatlantic is offline   Reply With Quote
