Old 07-30-2013, 10:05 AM   #33
stephen wilson
Sorry Ekam, but that's not true. If the Net offset is the same, your wheel bearings don't know if you have a spacer or not (assuming they are quality, and hubcentric). A +25mm offset wheel is effectively the same as a +35mm with a 10mm spacer. Anything that still fits in the stock wheelwells will NOT be enough to affect the wheel bearings.
