Have your system pressure tested to find the leak. Any shop or radiator place can do this. Identify the problem before you start replacing parts.
I just replaced the O-rings on the bleeder valve a couple of days ago. You have to remove the cover flap that surrounds the fill caps to see the bleeder valve and if there are is any leakage there.
