Old 07-29-2013, 04:00 AM   #7
Porsche_Padowan
Duralast pads
Originally Posted by owl1979 View Post
Hi Everyone,
I am slowly chipping away at DIY tasks on the 2001 Boxster base that I picked up a few weeks ago. Brake pads were supposed to be this weekend's project. The previous owner gave me a set of front and rear Duralast Gold brake pads, purchased at Autozone.
When compared to the OEM pads currently installed the surface area of the pad material is larger/higher. This is causing the pad material to touch the lip/edge of the rotor. I haven't seen this happen on my other cars and assume this is not good to use as it is.
I wanted to check in with this forum before I go out and purchase Mintex or Textar pads to replace these new Duralast ones.
(picture included - one pad shows that it is _higher_ than the rotor, but I just need to adjust this down to fit better, though I'm still not comfortable with the pad touching the rotor edge)
Any help is appreciated.
Thank you.
The pads will brake just fine but when they start to wear you will probably start to get some squeal. Is the pad that is overhanging fully seated in to the caliper?
There is a "edge code" on the pads can you tell me what it is? It will be on the side of the friction or plate or on the back. I can investigate a little further.
Porsche_Padowan is offline   Reply With Quote
