Old 07-27-2013, 05:02 PM   #11
AKnowles
AKnowles's Avatar
Keeny, I suppose it is possible, but the same pattern was on both lenses. In fact, I need to resand the passer side one as I didn't sand it enough to give it the same clear elns effect as the drivers side. The good news on both though is the cleaning seems to be holding up quite well.
My only problem to date is alignment. The passenger side is poiting too close to the center. When I adjust it the adjuster nut only moves it so far to teh outside and then it starts to move back inside. I think I need to adjust the tray at this point to fix the alignment issue.
PS: Thanks for all the information on this subject. I had no idea about the crazing either.
