Thread: RMS Tool Needed
Old 07-27-2013, 10:55 AM   #2
JFP in PA
Originally Posted by JAAY View Post
Is anyone willing to lend me their rear main seal too? I will pay shipping and take great care of it and ship it back with in a day.
You are asking someone to lend out a tool that is (a) hard to come by, and (b) cost nearly $500.
Another way is to use a 3 inch PVC pipe coupler:
A simpler, if not as elegant, tool can be made from a 3" CPVC pipe coupler (this is a straight sleeve with a small ridge halfway through for the plastic pipes to rest against) found at any Lowes or Home Depot:
Use the original flywheel bolts that are finger tightened until they rest on the center ridge, then use a cross tightening pattern until the correct insertion depth from the flywheel flange is reached.
A around $4, it comes as a ready to use tool for the DIY project that will probably only use it once in their lifetime instead of the $500 OEM tool??
