Old 07-26-2013, 04:58 PM   #26
Brad Roberts
Brad Roberts's Avatar
whoa.. that is a BIG plate!!
You leave it in test, and hit the "FIRE" buttons.
I typically mount a button inside for the driver, and obviously the one outside.
To prevent accidental release from inside the car, put a thin piece of silver tape over the recessed button hole (assuming they sold you a dash mounted push button for the cabin! They typically have a 1/2 inch deep shroud that mounts around the button. Put the foil tape over the shroud (so in an emergency, you have to push through the tape)
Humans have a tendency to push button's, the one time you forget to disarm it, will be when a neighbor kid jumps in the drivers seat, sees a red button.. and pushes it.
At least one per large event gets "set off" No joke.
COTA this year? PCA club race? I get a call from the scrutineers running the show.. "um Brad?, do you know someone here in Austin that sells the electric fire bottles"?
Yes Call xxx-xxx-xxxx
Engine Builds, Transmission Builds, Engine Conversions, Suspension Installs, Suspension Tuning, Driver Coaching, Data Acquisition, Video, SCCA/PCA/POC/NASA/GRAND AM/ALMS.
We have worked with amateur and professional drivers for over 26 years. In house machinist, In house fabrication. Our cars, our parts, our engines, our transmission's run nationwide at events every weekend. We work side by side with industry names developing parts.
Brad Roberts is offline   Reply With Quote
