Old 07-26-2013, 03:03 PM   #10
woodsman
woodsman's Avatar
so are you saying the spring rate slowly drops and this causes a similar drop in ride height?
and Brad- at -.5" rear ride height should my specs be this far off??? Are Taret arms a bandaid or a justifiable and expected cure? Are the offset bushings you make a .002" pressfit and have any ever split the cast arm after they're in use?
