I measured the ride height- FR is lower by 1" and RR is lower by .5"!! I was expecting an additional .5" lowering FR and RR...The FR I can live with but why is the suspension so out of spec after .5"lowering? I'm not totally susprised that the rear isn't as low as I expected since I bought the Tip set (my car is a 6-speed)as it was $250 cheaper. I thought hey I'll get a little higher spring rate (assumption) and more neutral handling--perfect! Maybe the rate's the same and the coil length is greater, hence less lowering???That's fine too but why's it so out of spec??? Dammit, new OEM parts and still more probs.
