Don't scare me here. My one question is, why do I need custom built axles?
Parts list.
All S parts.
throw out bearing and tube
Clutch kit
flywheel
I have the updated lever already
slave cylinder
new flywheel bolts
don't care about exhaust hanger stuff - easy enough to fabricate
I was going 6 speed because this is the second 5 speed that I've had that now rattles and moans while rolling in first and second gear. Am I missing something here? Brad you probably have the most knowledge - why do I keep having all these 5 speed tranny issues. Right now i'm on a cayman 5 speed. I dont miss shifts or grind gears and am running royal purple. It works perfect but is just noisy as hell. I may pull it tonight just to re install it if I find something that is rattling or loose.
Any info that i may not be aware of please help me out. I can cancel my tranny order if you give me good reason.
