Glad this is working for everyone that has tried it. My window still functions perfectly after all this time. I fixed the pictures at the beginning of this thread as I'm using a new free picture hosting service now.
Originally Posted by Dave S.
I finally got around to opening up the door panel to install my (hopefully) permanent fix for the problem of too much slack in the window regulator cable. The sympton of my problem was that the window would not drop enough to clear the top when I opened the passenger side door. The window would still roll up and down properly, it just wouldn't drop enough to clear the top. The window had excessive play in the cable system, which could be felt by rolling the window 1/2 way down and then pulling up and down on the glass. The window would easily move at least 1/2 inch up and down. (Update: I used to think it was because the cable stretched, but someone in this thread pointed out that there is a small plastic guide that breaks causing the cable to have excessive slack. - So I now believe this is truly a permament fix if done before the cable frays at the motor.)
I used a $3.00 bicycle brake cable adjustment barrel to take up the slack and add some adjustability to the window regulator system. Hopefully this will be a permanent fix. It was pretty easy to install and did not require the window regulator to be removed from the door.
I had to drill out the front lower corner bracket a small amount and I had to remove the original factory end from the cable housing. All of this was easily doable while installed in the door. This what the final fix looks like:
You may remember my temporary fix from another thread:
