Originally Posted by racerjsz4
hi, im new to the site. i just bought a 2001 Boxster S and love it, its time to get her some upgrades and i figured i get wheels and tires (dire need of tires)
here's the specs:
19x8.5 Front / 19x10 Rear
offset 55 Front / 10" ET42
or these wheels
18x8 Front / 18x10 Rear
offset 50 Front / 62 Rear
will these need spacers?
what do you think?
what looks better?
The fronts will fit ok with the 19's. Personally, I would add a 10mm spacer. The rears are right on with a +42 offset.
The fronts will fit ok with the 18's (ideally I would add a 10 mm spacer as well). However, the rear offset is way too high. You'll need to add a 20mm spacer.
