Old 01-22-2006, 11:22 AM   #6
Tool Pants
With the huge wheels being used the spare is going to be a thing of the past. Personally, I want an ordinary spare if possible because I had a gash once from a piece of metal and there is no way the goop would seal that. Also had a valve stem get cut and goop can't fix that. Plus if you are in the middle of nowhere, good luck waiting for a truck to show up. Then if your tire is not currently available....
The goop is cleaned out and the tire inspected to see if it can be patched (let's not get into the patch debate). Tire shops do not like that stuff inside a wheel because of the mess.
I have been waiting for Porsche to come out with a 987 spare tire retrofit kit, like they did for the Cayenne. So far nothing, but the parts are listed.
For you 987 owners gradyex on rennlist made his own kit for a 997, so you can do the same for a 987.
Tool Pants is offline   Reply With Quote
