Old 07-19-2013, 09:00 AM   #10
LuvTheBoxsterS
I also have a 2004 Boxster S and did the IMS retro, RMS, clutch, throwout bearing, water pump, and thermostat in 2012. The car had 42,000 mile when the work was done. The fly wheel was in fine shape. Did the water pump at the adivse of the garage doing the work. The pump has a plastic fin impeller. They have a tendancy to crack. Did all of this as a precationary measure. Now I can sleep better. The USD4,000, which included an oil & filter change was worht the money.
Glad to see you are doind the motor mounts. I did not do this and just had the front replaced a few days ago.
Good luck!
LuvTheBoxsterS is offline   Reply With Quote
