Thread: Tire width?
Old 07-14-2013, 05:17 AM   #1
LAP1DOUG
LAP1DOUG's Avatar
Tire widths are not very uniform. That is some manufacturer's "275" may be closer to being a "285" or visa-versa. The bast way before you purchase is to compare data from TireRack.com, or from the tire manufacturer's site.
That said, on my 986S, I am running 285 rears with Hoosier A6's, which generally run quite wide. These are a 11.5" section width when mounted on a 10" wide wheel. I have not rolled my fenders at all and this works, but if I was lowered a bit more there would probably be some contact.
So, running a 285 is possible, but it depends on wheel offset, ride height, and suspension stiffness (max wheel movement).
Take careful measurements.
Kippis
986S
991S
Van Diemen RF97
LAP1DOUG is offline   Reply With Quote
