Originally Posted by pothole
Ah, I see - you mean those are custom spring rates? Fair enough.
I meant that I very much doubt the standard spring rates for PSS9 for 986 you buy off the shelf are that stiff. If they're custom, obviously I wouldn't argue!
Yes they're custom. 9ff chose the spring rates based on the type of driving I was planning on doing. They're significantly stiffer than standard PSS9's. Most people that I know who have them, typically run theirs anywhere from 6 to 3 for street. I can't run mine any stiffer than 6 on the rear and 8 on the front unless I want my dental work to fall out.
