Old 07-12-2013, 07:13 PM   #14
Ian c
Originally Posted by Whippy View Post
Wow wow wow!!! Something I see here a lot is a bit of a rush to the most expensive and "worst case scenario" fixes!
I had a similar problem after a service and it was some sound deadening that hadn't been replaced properly after the work. These clips can slip off in time and all it needs is a tidy up and recoup everything behind your seats & in rear trunk back down....
I'm not saying it is that but its cheap so try it first!
I'd say its replies with sound advice on these cars and the parts that wear causing such a noise that will be a better clue to their origin , than tales of shoddy workmanship .....
However , I too look at everything when chasing down noises as , as i am at the moment .
Wd40 and blu-tak are my best friends
PS : What about just fitting an eBay cat-back muffler system
Ian c is offline   Reply With Quote
