Hi Maurice! This may be backtracking, and answered elsewhere, but is there a way to manually test if the upper microswitch is working? If I latch it the windows go up. If I unlatch it, they drop. With it latched, vs. unlatched, the alarm acts as it should. Does this mean it is working, or is there another sensor in there that detects something, which cannot be tested manually?
Currently, I have all the rods taken off the v-levers and am enjoying the car's manual mode, though the clamshell and top assembly rattle around a lot. I can live with that for now. Keeping an eye on things though. That trim at the back of the clamshell can come loose, it seems. Bungie cords, or some sort of spring to connect the old v-lever to the clamshell attachment point is my next project. Maybe adding some rubbing strips to keep it from clunking. Honestly, I like the manual mode a lot. It also allows me to fold the plastic window more perfectly as it goes down, so it doesn't crinkle up as much.
