I would be very concerned about mixing coolants. While not as much an issue as it was a couple years back, if you have ever seen one of these cars with the cooling system loaded with gel from incompatible coolants, or watched at the amount of time it takes to clean one of these messes up, you would be more than cautious.
Jeff, are you saying this is still an issue? From what I could find online in regard to this issue Preston stated their coolant could be mixed with any brand. Peak, and a few others followed similar bends and the issue was really with high concentrations of silicates precipitating out, but modern coolants are mostly low in silicates at this point.
