Old 07-09-2013, 09:58 AM   #16
Perfectlap
Perfectlap's Avatar
I don't think engine mods will have much effect unless they push you into a lean condition and start making thinks hot, or timing goes off. from what I've seen (check out insite's wideband o2 post) the ecu tends to keep even a heavily modified engine in the safe zone.
Yes but aren't m96 inherently hot-running even with OEM parts? If you're going to push the engine harder with aftermarket stuff, while using a 'conventional' oil, and no other augmented safeguards, aren't you inching the car closer towards unsafe temps on a fairly routine basis? In other words, If there is an 'event', the usual margin or buffer is no longer thus reaching a threshold breaking point more likely.
p.s.
i'm not an engine engineer I just play one TV.
BORN: March 2000 - FINLAND
