Thank you both - that is what it was. I felt backward toward the trunk and could feel a split where it was attached. Do you think ziptieing a baggy over it will be good enough to drive it to the shop for repair? How hard is it to do it myself when one end is under the intake and I can't see the other end?
I did ensure there is oil in it and that everything is closed up. So the only issue is if the baggy will hold the vacuum.
