Old 07-08-2013, 12:52 PM   #1
rosenfe
are you saying that you were not overheating until you took cap off to check coolant in overflow tank?was it running at right temp before that,was coolant at right level?.maybe your coolant cap is no good and taking it off merely was the tipping point so that it no longer holds pressure and possibly you have air in system after you added coolant as well as outdated cap.thats the simplest way to start.
rosenfe is offline   Reply With Quote
