			I am about to replace for the 3rd time ('99 with 105k).  First time I tried all the fixes to beef up the rubber grommets that were failing.  Worked for awhile and then failed.  So I got a new bracket.  Just a crap design.  Air bag weighs too much and it will eventually wear out the thin rubber.  Right now it is beep/beeping when it gets really hot out and the rubber becomes real pliable.  Soon it will happen even on a cool day.  I found a Torx unit at Home Depot that was long enough to engage for under $10 and has multiple other Torx heads on it as a bonus.
