			So today I was going to clean the throttle body... But first I disconnected the MAF to see if the idle was better. It was. So I thought then maybe it was a bad MAF and I didn't need to clean the TB. Upon inspecting the TB I saw that the ring/clamp from the airbox to the TB was completely loose! I mean all the way loose! Maybe that was the cause??? I cleaned the MAF again and tightened the loose clamp and the car seemed fine! Only time will tell though. I has been intermittent. Since replacing the AOS. I hope that the loose clamp was the main problem and my idle and throttle response stays good!
