Old 07-04-2013, 08:21 PM   #15
stateofidleness
Originally Posted by schoir View Post
Also, the "top open" idiot light on the dashboard display is supposed to light up the moment that you open the latch and press the button. It's supposed to go out at the end of the cycle when a microswitch is tripped. In your case on your 2000 Boxster, that microswitch is one of two microswitches located INSIDE the driver's side transmission.
Regards, Maurice.
Ahhh, see my idiot light doesn't come on at all (even just turning the key to the "on" position. It used to in the past every time. I didn't notice this before the top failed to go up that day.
Is the microswitch inside the transmission replaceable by itself or am I looking at a replacement transmission? If it is replaceable by itself, would you happen to know the latest part number for it? Is it replaceable without having to worry about all the "sync" issues between left and right if I don't operate it during the replacement process?
stateofidleness is offline   Reply With Quote
