Old 07-03-2013, 03:46 PM   #15
edc
550 Anniversary
edc's Avatar
I would reuse the existing rubber connectors and not use reducers. Also if you use the 996 Plenum you don't need a gasket or washers. You can also reuse your existing hose clips.
Current: 550 Spyder Anniversary- Carnewal exhaust - 100 cell cats - stainless manifolds - 4" underdrive pulley - poly gearbox mounts - rear lower alu brace - adjustable rear toe links
Sold: 986S - Zenith Blue - 18" Sport Classics - Black Zunsport grilles - Stainless silencer and manifolds - K&N panel - shortshift - M030 suspension - 75mm throttle body - custom 83mm intake - SmartTop - custom remap - MDS underdrive pulley
