Old 07-03-2013, 12:49 PM   #6
Laredo
If the battery is fine make sure ground connections between battery, body and engine are completely clean and tight, if you have an manual transmission and starter fails to operate check clutch pedal operated starter interlock switch. In an open circuit voltage test any voltage over 12.6 is fully charged. Perform a load voltage test after applying a200 amp load for 15 seconds at 80F the minimum voltage is 9.6. In may case the extra load for the failing IMS bearing was the problem.
Laredo is offline   Reply With Quote
