Front wheel area squealing
I've had this higher pitched squealing (sounds like a pig in pain) in my front left wheel area for almost a month now. I took it in (twice) to the mechanic and both times the squealing resided and they didn't hear anything. I had worn front rotors, they said it might be the brake pad rubbing against the rotor lip. So I ordered/replaced them...squeal still there. My tires are 2 months old so it's probably not tires.
Some days the squeal is softer then others, and it seems like when I drive for a bit it gets softer and SOMETIMES goes away, it can be sporadic. It normally starts at about 35-40 mph and stops when i get under that, it seems like the pitch is speed dependent.
I hear that wheel bearings have a lower "whoob whoob" type noise not a higher pitched squeal. Anybody have any advice on what to check or what could possibly make this noise?
