Old 06-30-2013, 04:44 PM   #5
Atomicblue99
Atomicblue99's Avatar
Clogged A/C drain
I agree, it sounds like a clogged A/C drain. I had a very similar problem in an old Dodge Dakota pick-up truck. The truck had ice cold A/C but the drain was clogged and condensation would collect in the ducting behind the dash. When I went around a corner cold water would pour out on my legs (or the legs of my passenger). I live in Florida, so the humidity is high. If you were running your system constantly in high humidity it could be that the drain is partially clogged and just couldn't keep up.
Atomicblue99 is offline   Reply With Quote
