This is a guess.
Perhaps the drain tube for your AC is clogged or partially clogged. If so, the condensation will collect in the heating / AC box bottom and spill over when turning a corner. It may have gotten better with the top up and windows closed because there is less humidity in the cockpit.
When you turn into a parking spot do you notice water drips along the path you took? If not, the drain hose is likely the source of the problem.
