If you be no power on the switched positive to the starter that you have confirmed with a meter , or by the old method of jumping the starter with a screwdriver , then you need to look at anything else in that circuit from the ignition to the starter , such as clutch switches that need to be depressed etc . And the electrical portion of the ignition switch (Audi part , fixing mine this weekend)
