Old 06-27-2013, 01:49 PM   #2
soucorp
soucorp
soucorp's Avatar
If all of your issues just started from changing a bulb, most likely it s not the ignition switch or light control knob.
Make sure the connection is tight, you have the correct bulb watts/volt/amps
If your problems started before a bulb change, it could be the light control knob, loose wires, broken bulb connector inside headlight unit.
Mine had a broken connector from rust and water that got into it, had to order a new piece.
good hunting...
soucorp is offline   Reply With Quote
