Old 06-27-2013, 12:09 PM   #1
The Radium King
The Radium King's Avatar
you could probably use the same mechanism and control signal as used by the resonance flapper on the intake to control a cutout on the exhaust - over 4000 rpm the cutout opens and bypasses the muffler. you would need to confirm that it could take the heat, need one on each side, and mebbe get a bigger vacuum tank to address the larger load.
