There are many postings with similar (but never identical) problem.
Easiest test would be to disconnect the battery for few minutes anf give it a try.
My best guess is that the "door is open" switch is stuck. Or in my case, faulty soldering inside the door lock mechanism.
Does the windoe drop a little when the door handle is pulled?
Does the window stay little down as long as the door is open?
And does the window go all the way up when you close the door?
If any of the condition exists, my guess is a bad switch in the mechanism
