Originally Posted by donjuan143
thanks for your reply
if i remove the Transmission Shift Lever Cable then the lever moves normally.
this happend when my car was parked and i started the car then moved the lever from park to nutral i heard a sound on the gear, (this sound i always hear it on my BMW when i move the lever from the park especially if my car is not parked on a striaght surface) my car drove normally until i parked it and couldnt move the lever to (P).
Hi,
If the lever moves freely when the cable is disconnected from the tranny, it would seem you've eliminated the Shifter/Lockout Mechanisms as possible causes.
This, and the noise(s) you describe, make the Transmission suspect. Try readjusting the Shift Lever Cable so that when the Shifter is in Park, there is no tension on the Cable - this is the recommended set-up. Then check to see if the Shift Lever will move through it's normal range, pay particular attention to the Gear Selection Indicator on the Dash to insure that you are actually engaging the various Gears. Hope this helps...
Happy Motoring!... Jim'99
