Old 06-18-2013, 02:15 PM   #11
soucorp
soucorp
soucorp's Avatar
Originally Posted by 99 Boxcutter View Post
For whatever reason, it takes 5 minutes or so of the car running for the oil gauge to raise. I know, it freaked me out at first, but that's just how it is.
Sounds like a bad sender unit or gauge. You should have it checked.
911 3.2 Carrera series (1984–1989)
4 things that I would check that won't start your car are these:
confirm or deny each is functioning properly:
Electrical -> Battery -> good ground -> starter -> alternator ->fuses
Spark -> clean spark plug -> wires -> coils
Fuel -> L-Jetronic with Bosch Motronics 2 DME (Digital Motor Electronics system) check relay
Air -> air filter, no blockage, no vacuum leak
Best
soucorp is offline   Reply With Quote
