Old 06-18-2013, 11:25 AM   #10
woodsman
woodsman's Avatar
For the record, I have found I am able to install the stainless lines with the stock 'lock- clip' device after bending it somewhat, into a revised shape. This is less than ideal as it appears to be a piece of hardened steel and as such should not be permanently bent as it makes it forever more fragile/ brittle. I'll report any failure of said piece(s) here. I wonder if there's a set of lines available which use their own device, instead of the OEM clip?
