Thread: "The Red Clip"
Old 01-17-2006, 09:25 AM   #22
MNBoxster
Originally Posted by BobMarley1
very well, I mean the sensor.
Is there a way to strengthen the "eye"?
I can lock my car, then wave my hand all around in the interior and the alarm will not go off.
Hi,
How are you locking the Car? If you use the Key or Transmitter, it takes 10 sec. for the Passenger Compartment Montioring to activate (IR Sensor) - you'll see the Dash indicator and the Central Locking Switch LED flask 1/sec. for 10 sec. The Dash Indicator will then flash 1/2sec.
If you lock the Car using the Central Locking Switch on the Dash, the Passenger Compartment Monitoring Function (IR Sensor) is disabled.
I regularly lock the Car, Top Down, w/ Red Clip, Windows UP. You have to have the arms of a Gorilla (not that they're not out there) to reach inside. My IR Sensor is pretty sensitive. I was at an outdoor Cafe' and watched a Bee fly into the Car and it set off the Alarm in under 2 sec. Hope this helps...
Happy Motoring!... Jim'99
