			Go ahead an change the regulator and motor. I did the window regulator first and still had slack as the motor's drive mechanism had some play in it. After I changed the motor, my passenger side window worked perfectly. I found a new OEM Porsche motor on EBay for a 100 bucks. You might have to hunt a little, but you should be able to find the parts for less than $250. Good luck!
