Driver's Window Doesn't Drop When Opening Door
Hi All,
Just bought an 00 Boxster S with 41k on the odo. I noticed the driver's window doesn't drop to clear the roof line when you pull the door handle, both outside and inside (pass side works fine). You can tell the motor moves the window VERY slightly though, when you just put pressure on the handles as if you were going to open the door.
I thought it could be the window regulator even though the window goes up/down with the buttons and the key/lock/hold function just fine, but another tell tale sign is the radio stays on when the car is shut off and the red radio security light stays flashing when I turn the ignition on, making me think it's a micro controller (not exactly sure which part this is yet).
Any ideas? Can I rule one out?
Thanks in advance, I'm so stoked to own my first Porsche. :dance:
