Old 06-13-2013, 04:08 AM   #16
soucorp
soucorp
soucorp's Avatar
Originally Posted by ArenaRed986 View Post
Very inspirational -Great job!! I just picked up the DRL's you recommended- Thanks for sharing!
Thanks and good luck on the LEDs. They look cool but here's a tip, you dont have to remove the front bumper to put them on, but you will need to make a small hole to run the wires into the rubber molded air openings on both sides of the grille as they are tightly fit and sealed off. when you peek a look, you will see what I mean. That rubber can be punctured to get the wire thru. You can get the DRL wiring harness kit that connects to the battery or do as I did and tap the side markers.
Its not hard, take your time, solder correctly and it will work like a charm.
Best
soucorp is offline   Reply With Quote
