P1539 Camshaft Adjustment, Bank 2
Actuator triggered, no active position.
Potential causes:
- Open circuit in triggering wire.
- Open circuit in B+ supply.
- Actuator faulty.
Check the connector and the wiring to the cam actuator the right side of the car.
B+ would be 12 volts.
If the actuator is bad then I suggest letting a shop do that. The cam cover has to come off.
If it is properly connected and there is no wiring damage and the unit is getting the 12 volts -- then it pretty much has to be the actuator.
Sounds right... fix or replace things along this bus line and your car be back up in no time.
Best
