Old 06-13-2013, 03:58 AM   #1
soucorp
soucorp
soucorp's Avatar
P1539 Camshaft Adjustment, Bank 2
Actuator triggered, no active position.
Potential causes:
- Open circuit in triggering wire.
- Open circuit in B+ supply.
- Actuator faulty.
Check the connector and the wiring to the cam actuator the right side of the car.
B+ would be 12 volts.
If the actuator is bad then I suggest letting a shop do that. The cam cover has to come off.
If it is properly connected and there is no wiring damage and the unit is getting the 12 volts -- then it pretty much has to be the actuator.
Sounds right... fix or replace things along this bus line and your car be back up in no time.
Best
soucorp is offline   Reply With Quote
