Old 06-12-2013, 06:20 PM   #2
soucorp
soucorp
soucorp's Avatar
Originally Posted by tommy583 View Post
My fuel light came on at the end of a weekend trip. I was running late for work Monday morning. So i just put in $15 to raise the fuel level for my drive to work. When i started the car i noticed that the fuel gauge didn't raise at all. Hmm. Continue to work on the hi way. When i get off i have to stop at a light. Car stalls. Starts right back up, but now gauge reads over 1/4 tank. Make it to work.
I drove to the store on lunch, no problems. On my way home from work the car stalled or wanted to stall every time i came to a stop. Like the second i lift my foot off of the gas and push the clutch in the RPM's drop to zero.
I have an appointment at the shop on Friday. I was just trying to find out if anyone has any ideas. I hooked an ODBII scanner to the car and didn't get any codes.
Sounds like it could be a vacuum leak that's causing it to stall. I would begin with the basics- vacuum leaks, loose connector wires, MAF dirty or going bad? No check engine codes come up -surprised? You should crack open the engine compartment and have a look making sure hoses and things are tight on. Another possibility is a faulty fuel pressure regulator. Why? The fuel pressure regulator maintains proper fuel pressure to the fuel injectors. Problems with this device will likely result in a fuel starved engine thus it will stall. If all of your problems only occurred after that 3-4 gallon fill-up, maybe water in the gas ?
soucorp is offline   Reply With Quote
