Old 06-12-2013, 10:02 AM   #10
Wilson01S
There is a 50% chance you are 360 degrees off for setting 4-6cyl cam timing. To verify remove the 1-3cyl green cam plugs to visually verify 1-3cyl cams are timed right. If the 1-3 cams are correct for TDC then 4-6 bank is 360 degrees off & you need to turn engine 1 revolution CLOCKWISE back to TDC. 1-3cyl cam notches will now be upside down & 4-6 cams are ready for install & timing.
Is there a safe way to turn this engine over without having the cylinder 4-6 cams installed? I can hold the chain and sprocket while someone turns the engine over for me, but I do not want to over pressurize cylinders since all 12 valves will be closed
2001 Boxster S 6speed- weekend warrior
2015 Explorer Sport- New DD
2011 Taurus SHO- Sold
2010 CBR1000RR- Sold
Wilson01S is offline   Reply With Quote
