Old 06-11-2013, 12:13 PM   #5
Polaris
I have the kicker 6.5" shallow mount subs in the doors and the small-size MTX TD-500.1 mono sub amp powering them and it is WONDERFUL!
I also replaced the stock amp with the MTX TD75.4 4x75 watt amp for the dash and added four 3.5" drivers into the rear shelf compartment. I got this amp combo because they both support 2 ohm loads on each channel, so I have the kicker subs run in parallel for a 2 ohm load on the 500.1 amp, and I have the rear speakers also wired in parallel so 2 of the 75.4 channels are running at 2 ohms, and the fronts in the dash are at 4 ohms.
The really great thing about the MTX amps is that I fit both of them on the stock amp's mounting panel, and it looks great. I'll post some pics as soon as I get a chance.
Polaris is offline   Reply With Quote
